3/8-16 tap -> 5/16 (.3125) drill
if you brake it down and think about it , the chart is easy to use
you need the cutter dia. to fit in the drilled hole plus have enough cutter to cut the thread you need
the chart tells you the max and mins for thread per inch (this will not change for the dai.)
so as long as you have a cutter that will fit in the hole and can cut the thread you need you will have a cutter you can use
LinkBack URL
About LinkBacks
