Page 1 of 2 12 LastLast
Results 1 to 12 of 24
Thread: Ideas to machine this part
    Mar 2012
    Trying to machine this profile in 3/4"x3/4" CRS, 24" long. Problem is after 1st side is machined, part looks like a banana and must be pressed back into shape to do the 2nd side. Angle on each side is 20deg. Any ideas? I'm very close to making my own machine with a spindle on each side and machine them both at once. More on that later if needed. Still thinking there has to be a way to do this simply.
    Greg
    Attached Thumbnails Attached Thumbnails Ideas to machine this part-gmr-0389.jpg
    Mar 2006
    CRS is full of mechanical stress from the cold rolling process. That's one of the reasons it goes "bananas". How are you holding/fixturing the pieces now?
    Dick Z
    DZASTR
    Mar 2012
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    In a jig using the 2 sides (top and bottom on photo) to do the first cut. But I have to take it out to flip it for other side (in another jig). That's when it warps. Once pressed back into shape, it works fine. Trying to avoid that operation. I also don't want to stress relieve before since I have a lot of these to make in the future.
    May 2004
    So, when you take it out after the second operation it does not warp again? Or are you saying at that point, you do not care if it is warped or not?
    http://www.kirkcon.com/
    Mar 2012
    Quote Originally Posted by txcncman View Post
    It is. But I can deal with it because it get's inserted (the narrow end) into a straight slot and plug welded from the bottom. This straightens it out.
    Greg
    May 2004
    If I were going to run this job, I would set up 3 vises with extra long soft jaws on my mill and run it as in the first picture. Then I would cut some extra long soft jaws to hold and cut it as in the second picture. I would let the vises and my hammer do all the straightening that was needed.
    Attached Thumbnails Attached Thumbnails Ideas to machine this part-gmr-0389_op1.jpg   Ideas to machine this part-gmr-0389_op2.jpg
    Mar 2012
    Ya, that's how it is setup now (except with a fixturing jig for many bars at once). Problem is I need to do a good 1000 of these at a time. I think I'm gonna build something like this picture. Just need to figure out HP and tooling (thinking 1" or 1-1/4" indexable endmill, APKT or the like, 2 or 3 inserts) to be able to cut everything in one pass (just under 1/4" doc at thickest point). I don't care if I have to go 6ipm at 500RPM. I can make a feeder and have it all automated. I can make it weigh a ton and as rigid as possible. I don't even care about finish, it all gets galvanized after welding anyways. All that's important is angle and repeatability in same batch.
    Attached Thumbnails Attached Thumbnails Ideas to machine this part-gmr-0631-tst.jpg
    May 2004
    I think the point was your jig was not working and you had to straighten each piece before proceeding. My solution takes out the straightening step.
    If you are going to build a machine, you might want to go horizontal with a finish form tool and with some stock and part guides and feed rollers. Place the bar in one end and it comes out the other finished. Probably want to shoot for the 10 HP range.
    Mar 2012
    Sorry for the confusion. I wanted to see if there was something I was missing and was a way to make this part without it bending between the 2 steps.
    As for 10HP, on each spindle? Or 5 on each, 10 total? Seems like an awful lot. Yes, the rollers are actually pictured on the picture (although very feint). Will be using die springs on top and one side to squeeze everything together for positioning. My problem is the 10HP. Will be running it on 550V, but that's still a bear of a motor. I was thinking more 2HP on each spindle (another seperate motor/gearbox for the feed). As I said, don't really care if it goes slow. Trying to limit costs.
    May 2004
    I was referencing 10 HP for the entire machine, power feed rollers and all.
    Apr 2009
    You might consider starting with some 7/8" or 1" bar and rough three or four sides before cleaning it up in a second pass.
    Registered fizzissist's Avatar
    Apr 2006
    Quick 2cents ....
    If you're going to consider a special machine... consider sawing, w/ 2 saws opposed at the desired angles, staged with supporting rollers.
    Looking to me like you need to stress relieve the mat'l first...
    I'm curious why you need CRS as opposed to HRS for this part... nonna my business, of course...but ... (I personally despise HRS, but there's times when it's just plain easier)
    ...For the quantities you're looking at, you might also consider
    Cold Drawn Steel, Cold Drawing, Hot Rolled Steel, Hot Rolling, Hot extruding, Extruded Steel Shapes, Steel Extrusions, Cold Rolling, Cold Forming, Roll Forming Manufacturing Processes
    Would be worth a quote.
  • Page 1 of 2 12 LastLast
    1. Brand New Here Need ideas for a 4x8 Machine
      By bean_086 in forum CNC Wood Router Project Log
      Last Post: 01-03-2012, 07:27 AM
    2. Complex part with too much deburring...ideas are nice
      By ChristianK in forum CNC Swiss Screw Machines
      Last Post: 09-03-2009, 11:32 PM
    3. Any ideas on how to reduce chatter in hard part
      By levelzero in forum General Metalwork Discussion
      Last Post: 07-10-2009, 09:49 AM
    4. Any ideas how to scan and trim this part....
      By Normsthename in forum Digitizing and Laser Digitizing
      Last Post: 02-27-2007, 02:35 PM
    5. Ideas generative machine
      By broken arrow in forum Post Processor Files
      Last Post: 07-24-2006, 06:09 PM
