Results 1 to 4 of 4
Thread: engraving
    Registered dcutler35's Avatar
    Jan 2012
    Unted States
    engraving
    I would like to start engraving parts that I machine. I have never engraved with the cnc before I was wondering what type of cutter and how I should go about programming it the material is 304 ss and I will be using mastercam x4 any suggestions greatly appreciated
    May 2004
    Sometimes I just use a #1 center drill or a #0. Or you can get carbide engraving tools. For some reason I am guessing you do not have any tooling catalogs or have spent much time browsing the tooling web sites. Try MSCDirect, Travers, and Grainger to start. Most of the time, the tool listing in the catalog will tell you what it is designed for.
    http://www.kirkcon.com/
    Jan 2012
    Unted States
    feeds sppeds depth of cut ?
    i want to engrave .250 tall letters into the face of aa workpiece instead of steel stamping them what should i make the final depth and where would one get feeds and speeds for engraving? I checked out MSC they have quite a few engraving tool how would I know what would work best for stainless 304H
    May 2004
    Almost all tool companies have what are called "application engineers" working for them. Call them and ask to speak with an application engineer.
  1. Need Help!- Rabbit RL_6040 Laser engraving/cutting machine Rabbit RL_6040 Laser engraving/cuttin
    By piinkpnthr in forum Want To Buy...Need help!
    Last Post: 02-27-2012, 12:20 AM
  2. Distinction between laser engraving between special LGP engraving machine when produ
    By CUTCNC in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 11-21-2011, 03:46 AM
  3. Need Help!- V22 Help with Engraving!
    By hodge98ws6 in forum BobCad-Cam
    Last Post: 08-07-2008, 07:21 PM
  4. Engraving on an arc
    By YV600 in forum Haas Mills
    Last Post: 03-31-2008, 01:46 PM
  5. Engraving
    By camtd in forum Surfcam
    Last Post: 09-05-2006, 11:22 PM
