  #13
Old 08-20-2003, 01:43 PM
HuFlungDung's Avatar
Moderator
Originally posted by woody5
What's a floating tap holder?
Its a wooden tap chuck
Actually, it is a chuck that is designed to hold a tap, with some spring loaded flexability in the radial and axial direction. It is commonly used to compensate for lead errors between the tap and the feedrate of the machine's Z axis.
It has a little bit of radial float, too, so it will allow the tap to align itself with a slightly out-of-position hole. Thus, it will work in the same way with a reamer. It is not necessarily the ideal answer, because the tool does wobble a little until it gets started.
  #14   Ban this user!
Old 08-21-2003, 11:59 AM
E-Stop is on a distinguished road
Originally posted by Bill
I will be reaming 6061-T6 90% of the time. I am waiting for reamers to start testing. We will c-dril, drill 31/64, G13 to leave .004 per side, ream .5010. Speed & Feed for the reamer is at 2600rpm and 40ipm, this is in the ball park so we can test. We have a floating tap holder should i G13 the hole to .5000 to get a good start ?
Thanks, Bill Johansen
That's a bit fast, Bill. In 6061-T6 reaming a .501 hole I would start at about 688 RPM (90 SFM) and about .012 per rev feed, which would be about 8.25 IPM in this case. Your stock of .004 per side is pretty good. I usually shoot for .004-.006 per side.
I can't stress enough the importance of having a 'good' hole before you ream it. The reamer can only do so much and making sure the pre-reamed hole is good will insure consistency.
Old 08-23-2003, 12:15 PM
Moderator
Dan B is on a distinguished road
...and never run the reamer backwards when retreating out of the hole.
Dan
  #16   Ban this user!
Old 08-23-2003, 01:37 PM
hardmill's Avatar
hardmill is on a distinguished road
+1 E-STOP
On the speeds & feeds
Also a floating reamer holder is what your after.
A tap driver is a diff. tool.
PEACE
Old 08-23-2003, 06:06 PM
*Registered*
jonbanquer is on a distinguished road
If he's double drilling he should be able to go with less
than .004 to .006 per side. The reason I say this is I often
have to make dull reamers work / last and the less they have
to cut the more they last. Ahhh...you learn so much working
in a small job shop which won't spend a penny on tooling,
machine repair, modern CAD/CAM, proper coolant upkeep, etc.
Of course I'm probably the only one that has to deal with this
situation. LOL :>)
jon
Old 08-23-2003, 08:46 PM
Gold Member
Ken_Shea is on a distinguished road
Reaming lube, feed/speed
Hu I have seen your mention of using WD40 on several occasions, do you have good results on other machining uses?
In the firearm business I do my level best to see that no one uses it.
I do like the smell though
I was also kinda taken back at the slow speed and feed recommendations on the reaming of aluminum, having very little experience reaming I would most certainly have started much faster.
Thanks for the tips
Ken (Shea)
Old 08-24-2003, 12:20 AM
*Registered*
jbtech is on a distinguished road
jon
I think you are confused. What's this about a small shop?
Old 08-25-2003, 10:28 AM
Moderator
Re: Reaming lube, feed/speed
Thanks for the tips
Ken (Shea)
Hi Ken,
No I don't like to use WD40, but I use it because it seems to work good with reaming. It can also keep a cutter from clogging when doing engraving or small endmill work in aluminum.
I hear it attracts moisture and causes rust after it evaporates. Is this why you do not recommend it?
  #21   Ban this user!
Old 08-25-2003, 12:49 PM
Bill is on a distinguished road
To the group I have not had time to do testing for the reaming, got asked to work on another project, High Speed Machining of O-1, already talked to Hardmill and set me up.
Thanks again for all the info,Bill Johansen
Old 08-25-2003, 03:07 PM
Gold Member
Wd-40
"I hear it attracts moisture and causes rust after it evaporates"
You heard right Hu, it will absorb atmospheric moisture after a while, the higher the humidity the quicker it happens. It does make for a fairly good/cheap cleaner and flushes out rust well. WD40 is about 50 years old so its technology is outdated at best. I hear they manufacture 1,000,000 cans a week for the USA alone, pretty impressive actually but I will pick another product for firearms.
  #23   Ban this user!
Old 07-01-2007, 12:22 PM
MaximumBob is on a distinguished road
Quick [Related] Question
I'm trying to ream an accurate hole in a 1/4" thick 6061 Al pulley that I'm making. The finished hole size will be 0.500. How much should a leave for the reamer. Currently the hole is 0.478 which means the chucking reamer will have to ream 0.011" - is this about right? The work is being done in a lathe.
Thanks,
Bob
