Old 11-10-2005, 04:03 PM
Peten is on a distinguished road
Spindle speed control and coolant pump
Hi all,
Soon I'll receive my Taig CNC(2018 ) with Xylotex Kit.
How can I control my spindle speed with software (Mach2,TurboCNC) without changing the belt manually ?
Can I do it using only my Xylotex board ?
Also , If I have a coolant kit , how can I control it from the software as well?
Thanks,
Asi
Old 11-11-2005, 05:05 PM
CNCgr is on a distinguished road
With a Xylotex only and no additional harware you probably can't. You can use one axis to drive a DigiSpeed board.
With a relay on an output pin (this should help).
Old 11-12-2005, 05:07 AM
CNCgr,
Appreciate your help.
As for the Digispeed , I have been told it won't work with my Original Taig motor :frown: .
Thank for the "heads up" for the coolant kit. Now I have to learn some electronic.
Asi
