Results 1 to 7 of 7
Thread: VFD and motor selection
    Registered FannBlade's Avatar
    Jun 2011
    Guys I'm ready to order VFD and motor for my lathe and need some help with motor size and if VFD I have listed is a good unit. The reason for the GS2 is it has a removable front panel that I can mount in my new control panel location.
    Also going along with the post I was planning on this BOB board. C11 I also have a C10 here but looks like the C11 is what I need for the VFD and will be enough for future expansion...but not sure.
    Here is a post I made in my build thread.
    Quote Originally Posted by FannBlade View Post
    Time to think about a motor. Here is what I have had book marked for a long time now.
    1hp Steel series
    GS2 VFD drive
    Not sure how HP rating cross reference to what I had. Original motor is single phase 3/4 hp and seemed to have plenty of power.
    But I just found a Baldor 1 1/2hp cast iron inverter motor (1800 rpm) used for $60 (local pickup)
    I know that's a great price although I would need to jump up one model on the drive to a 2 hp unit making price very similar. Any thoughts?
    While on the subject I was planning on a 1 to 1 ratio (1800 rpm). Will I have enough control on speed with the VFD to lower RPM's or should I go 2 to 1 (spindle 3600 rpm) or go with a 3600 rpm motor?
    Original spindle does have triple pulley so I could just use it for now but it has an incredible amount of runout.
    I guess my main question is how well does a VFD control speed?
    Can the model listed be controlled with Mach3 with the proper BOB?
    My CNC Conversion
    My CNC build: http://www.cnczone.com/forums/genera...ml#post1059321
    C-Constant
    N-Nonworking
    C-Contraption
    Jun 2011
    OK then.
    I found some old posts that answered some of my questions.
    I ordered the 2 listed if it's to small I will use it on my mill.
    C-Constant
    N-Nonworking
    C-Contraption
    Dec 2003
    Here is a link to run it in the Modbus mode.
    Modbus to run GS-2 drive?
    Jun 2011
    Thanks Al
    I bookmarked it for reference. Can't believe I didn't find that last night when I was searching. Looks pretty involved but will definitely give me a starting point.
    C-Constant
    N-Nonworking
    C-Contraption
    Jun 2011
    Quote Originally Posted by Al_The_Man View Post
    Hey Al
    I was wondering if the cnc4pc C23 bob will run my VFD without the Modbus adapter.
    Here's wiring diagrams.
    Attached Thumbnails Attached Thumbnails VFD and motor selection-vfd.png   VFD and motor selection-c23.png
    C-Constant
    N-Nonworking
    C-Contraption
    Dec 2003
    AFAIK the CNC4pc will simulate the pot function fine so it should work OK on practically all VFD's.
    Jun 2011
    Good deal
    C-Constant
    N-Nonworking
    C-Contraption
    1. motor selection
      By Jack000 in forum DIY CNC Router Table Machines
      Last Post: 04-14-2010, 09:49 AM
    2. Newbie- Motor selection ...
      By arvidj in forum Phase Converters and VFD
      Last Post: 02-07-2009, 03:31 PM
    3. Motor selection help?
      By Ben Colby in forum Bridgeport and Hardinge Mills
      Last Post: 05-24-2007, 04:07 PM
    4. VFD and motor selection
      By wildcat in forum Industrial Hobbies (Support forum)
      Last Post: 11-28-2006, 03:35 PM
    5. Motor selection
      By Konstantin in forum DIY CNC Router Table Machines
      Last Post: 03-14-2004, 01:08 AM
