Results 1 to 3 of 3
Thread: Need advise on Mill upgrade.
    Registered Drools's Avatar
    Feb 2009
    I was hoping someone could tell me if the hardware on this mill would be compatible with Mach3? What would need to be changed to make it compatible?
    Thanks for the help.
    Attached Thumbnails Attached Thumbnails Need advise on Mill upgrade.-construction2012_111.jpg   Need advise on Mill upgrade.-construction2012_117.jpg   Need advise on Mill upgrade.-construction2012_119.jpg   Need advise on Mill upgrade.-construction2012_120.jpg
    Need advise on Mill upgrade.-construction2012_121.jpg   Need advise on Mill upgrade.-construction2012_122.jpg   Need advise on Mill upgrade.-construction2012%2520110.jpg   Need advise on Mill upgrade.-construction2012_113.jpg
    Thank You.
    Registered aarongough's Avatar
    Feb 2007
    I don't see any reason why it wouldn't be compatible with Mach3. You've got individual motor controllers, and a parallel port breakout board in there... You just need to trace which parallel port pins hook up to which driver/other function and enter all that info into mach3
    Registered arizonavideo's Avatar
    May 2008
    I haven see that exact mill before, do you know what mill it is based on?
    It does look like it has a standard PP interface so it should work with Mach3 just fine.
    Nice mill BTW
  1. Newbie- Need mill advise please
    By Mr. D in forum Wood Lathes / Mills
    Last Post: 10-15-2009, 09:08 PM
  2. Newbie- Need some small mill advise please
    By Mr. D in forum Benchtop Machines
    Last Post: 10-11-2009, 03:21 PM
  3. Need advise on BP series 1 Boss CNC upgrade
    By lkasdorf in forum Bridgeport and Hardinge Mills
    Last Post: 03-08-2007, 05:53 PM
  4. Need advise on a servo mill
    By Pinhead in forum Benchtop Machines
    Last Post: 02-02-2005, 05:57 AM
  5. Need to CNC my mill quickly - advise?
    By SRT Mike in forum General Metal Working Machines
    Last Post: 03-15-2004, 01:10 PM
