Old 02-02-2012, 01:26 AM
lonnie1994 is on a distinguished road
Question building a cnc mill, problem
ok so pretty simple i have all the axis sorted how to program it the plans and everything made, my problem is how to power it? i have an electric die grinder (isnt called that but cannot remember odd name) i could use but useless for metal, i also have a drill press i could use but have heard the bearings wont handle metal, so what im wondering is what can i buy and put together to power it?
Old 02-02-2012, 11:45 AM
siam is on a distinguished road
Milling Head idea
How big is your machine? What are you planning on milliing, and how fast do you need to go? Production work or just hobby needs?
I recently finished my own CNC mill and opted to purchase a milling head made for the Mini Mill (LittleMachineShop.com #1663). For $300 it came with 1/2 HP DC motor, variable speed control box, R8 spindle, and 2 speed gear box. This unit has no seperate spindle feed, (you must move the entire head assembly) which suits my needs, but not be a good match for you.
Good luck, and post some pics when it's completed.
Old 02-03-2012, 06:54 AM
thanks heaps im wondering if there is a way of getting a drill press and putting a milling collet/chuck setup on it, and making some of the parts a tad stronger to handle the sideways forces, as well as adding just general strength all round i do not have a great deal of knowledge on mills so if anyone knows if a mill chuck will go on a drill please tell
Old 02-03-2012, 08:02 AM
Drill presses make poor milling machines. I'd suggest buying or building your own milling machine.
Dick Z
DZASTR
Tags
3 axis, cnc milling machine, collet, help!, motor help
New Machine Build- Building a CNC Mill -- parts? mattgangi DIY-CNC Router Table Machines 12 05-25-2010 08:36 PM
Use a robotic arm instead of building cnc mill? SCCoupe DIY-CNC Router Table Machines 10 06-20-2007 03:23 PM
Building a CNC mill. Ariox Hobby Discussion 16 09-15-2006 03:06 PM
Building a manual mill ZipSnipe Benchtop Machines 6 03-09-2006 11:13 AM
Building CNC mill Machine. Need Advice Marek13 CNC Plasma and Waterjet Machines 5 03-05-2006 06:09 PM
