Results 1 to 3 of 3
Thread: Press or Mill
    Nov 2011
    Press or Mill
    Do you think a 12 ton press could stamp/emboss a 24 gauge zinc alloy 1 1/4 " round disk? Would I need someone to make me a coining die or would just getting it milled. The artwork is just an example and the reason I ask about the press is I do own one. I am not sure I am using the right term like coining,die,stamp or is this embossing?
    May 2004
    You would have to mill the die set. Depends on quantities. I think 12 ton could handle it. Might have to make progressive dies.
    http://www.kirkcon.com/
    May 2007
    Here is a coining press, says 30 ton for "dime and nickel size".
    Coining press for sale
    Type an hardness of the material will affect it but I think you are a bit optimistic at 12 ton for something 1.25" diameter.
  1. New Machine Build- Converting a drill press into a Mill
    By adprinter in forum Benchtop Machines
    Last Post: 01-05-2013, 01:44 AM
  2. Drill press use to mill copper ?
    By boy_gameover in forum General Metal Working Machines
    Last Post: 07-31-2008, 03:39 AM
  3. drill press / mill
    By exawatt in forum Mini Lathe
    Last Post: 10-04-2007, 12:27 AM
  4. Converting Heavy Duty Drill Press to Mill: Help!
    By SpeedsCustom in forum Mechanical Calculations/Engineering Design
    Last Post: 09-12-2006, 10:45 PM
  5. Really Basic Drill Press vs Mill Question!
    By diarmaid in forum General Metal Working Machines
    Last Post: 05-17-2006, 03:53 PM
