Results 1 to 4 of 4
Thread: Looking for an accurate indexer for grinding...
    Sep 2005
    Hi, I am trying to find an accurate method to index a part in 90 degree increments so we can grind 4 sides square on a cnc grinder. so I need the indexer to be able to be automated somehow.
    I can't seem to find anything like this other than CNC rotary tables which seem quite expensive.
    I would entertain building something as well.
    If anyone has experience with something like this I would like to hear your thoughts!
    Mar 2006
    There are indexers out there that index with "M" functions, not a fourth axis. Usually, far less $$$$$$$$.
    If indexing is the only automation you require, the indexing could be accomplished by a programmable controller.
    Dick Z
    DZASTR
    May 2007
    This is not going to be of any help, but in my experience, the words.
    Automatic (M code activated)
    Accurate (for typical grinding type work)
    Can stand up to a grinding environment
    and
    Inexpensive
    Have never be see in the same sentence.
    Mar 2006
    The indexers I'm familiar with use a Hirth coupling to locate the position. They are quite accurate. Voith sells them. International Machine & Tool (Warwick R.I.) sold indexers, but I don't know if they're still there.
    Dick Z
    DZASTR
  1. Getting Accurate Readings
    By coolantman in forum General Metalwork Discussion
    Last Post: 03-16-2009, 07:29 PM
  2. Why is surface grinding so accurate...
    By WilliamD in forum General Metal Working Machines
    Last Post: 07-22-2007, 07:14 AM
  3. What is more accurate
    By CNCadmin in forum DIY CNC Router Table Machines
    Last Post: 06-07-2007, 06:49 PM
  4. What is the most accurate CNC?
    By cooler21 in forum Commercial CNC Wood Routers
    Last Post: 03-25-2007, 08:27 AM
  5. How accurate?
    By bearwen in forum JGRO Router Table Design
    Last Post: 02-19-2006, 09:07 AM
