Results 1 to 2 of 2
Thread: ProtoTrak AGE-2 lower control unit
    Jan 2007
    Hi All,
    I recently purchased a ProtoTrak AGE-2 controlled knee mill. It's been running fine....but, we had a power failure last week and now the machine won't come up.
    I ran the Logic Cable test and the pendant is working fine. All the fuses are good. All the connections are tight. But the CPU isn't booting up. I'm guessing it's a power supply failure as I have no lights inside the lower unit. ProtoTrak tells me I need to purchase a new lower unit....Many $$$ for me right now. Reasonable compared to other machines, though.
    Has anybody had a similar problem? And, have you just replaced the power supply yourself? Which supply did you use?
    Thank you for looking and thank you in advance for ANY help!
    Andy Pullen
    Clausing 10" x 24" lathe, ProtoTrak AGE-2 control on Sharp knee mill, Sheldon 12" shaper, Reed Prentice 14" x 30" lathe
    Jan 2007
    Update! Now I have another issue.
    Hi All,
    I replaced the power supply in the control and the "lights came on". The DRO works as it should. When I tried to jog the table; I got an "E Stop Engaged" message.
    I didn't set the E Stop and tried to set it and unset it several times, but I'm still getting the message. There must be an interlock in the control and I need to clear it. Does anybody know how to clear it?
    The manual was no help. It just says to disengage the E Stop.
    Thank you!
    Andy Pullen
  1. Post for Prototrak 1630SX lathe SLX control
    By cncharleydude in forum Post Processors for MC
    Last Post: 01-07-2013, 11:52 AM
  2. Need Help!- How to Park Lower Turret mazak Mark IV Integrex Matrix Control
    By SteveCADCAM in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-14-2012, 09:03 AM
  3. Need Help!- CamWorks Post for ProtoTrak DPM V3 with SM control
    By toolmakerdude in forum CamWorks
    Last Post: 09-08-2011, 06:17 PM
  4. Need Help!- checking out ProtoTrak control
    By RH68 in forum General Metal Working Machines
    Last Post: 06-03-2010, 06:33 AM
  5. Need Help!- Prototrak MX3 on an EDGE 3 control?
    By klrskies in forum General CAM Discussion
    Last Post: 04-28-2010, 08:51 PM
