Results 1 to 4 of 4
Thread: How can I Make a Drawn Slot in Sheet Metal
    Dec 2005
    Can I produce the feature shown in the attached JPG with a 20 ton shop press? Material is 12ga steel.
    Tools I have available are CNC plasma, mill, lathe, brake and shop press.
    Thanks for any advice.
    Attached Thumbnails Attached Thumbnails How can I Make a Drawn Slot in Sheet Metal-drawn-slot.jpg
    Registered fizzissist's Avatar
    Apr 2006
    You might be pushing the limits with a 20ton and 12ga....but making a male mandrel and forming the pre-cut hole into a piece of die makers rubber would be worth a shot, if you're just making a prototype.
    Otherwise, you've got the mill to easily make the male and female die components for a simple forming.
    Dec 2005
    Thanks for the feedback. I would like to make something to process 100/month. My knowledge of sheet metal processing is limited. Would I be constructing a tool like this?
    Attached Thumbnails Attached Thumbnails How can I Make a Drawn Slot in Sheet Metal-tool.jpg
    Jan 2006
    barnon
    Check google for "dimple dies". These are used to make "speed holes" in peoples race cars and rock crawlers and choppers and whatnot. They don't do quite as much as wht you have modeled there and they are round, but that should give you an idea. Lots of guys are using them on their HF shop presses.
    Good Luck
    Matt
  1. How to make a T-slot table that's flat, true and rigid?
    By ddgman2001 in forum DIY CNC Router Table Machines
    Last Post: 10-01-2010, 01:29 PM
  2. Best way to make a deep slot. Drill Chain?
    By Kingjamez in forum General Metalwork Discussion
    Last Post: 09-06-2010, 01:52 AM
  3. Sheet metal help!
    By revwarguy in forum General Metalwork Discussion
    Last Post: 07-03-2010, 07:29 PM
  4. Need Help!- nx-sheet metal
    By sk96_me45 in forum UG NX
    Last Post: 04-30-2010, 12:58 AM
  5. anyone make their own t-slot linear bearings?
    By rkremser in forum 80/20, TSLOTS and other Aluminum Framing Systems
    Last Post: 06-09-2005, 02:03 PM
