Results 1 to 8 of 8
Thread: VTL Brand Suggestions Needed
    Dec 2011
    We're looking for a vertical lathe with 46" or greater max turning. Live tooling is possible. Full CNC preferred, but not a requirement.
    Looking to spend 350k or less. There seems to be a hole in the market, where you can either buy 24" max turning VTL for a decent price, or you can buy a 6ft max turning monster for 1.2 million. We're looking for something in the middle.
    Any brands that you gents might suggest to look at?
    Thanks in advance!
    Feb 2009
    Dec 2011
    The Mori Seiki NVL is in the 600k or more range, is it not?
    Mar 2006
    How about a 48"CNC G&L VTL? Probably a bit pricey new but a good used one should be available.
    Dick Z
    DZASTR
    Feb 2009
    Quote Originally Posted by ScrapMetalDave View Post
    I'm sure, if not more. The Youji should be in your price range though.
    Dec 2011
    I appreciate all the responses. I'm going to look into the Youji machines. Anyone have any experience with them? Is the construction basically like a VMC with a VTL's table?
    Feb 2009
    No. They are a true VTL, the one we have has the movable cross rail as well as the Z axis box ram. GIANT box ways on this thing as well. Make sure you get one with the Fanuc controller if your going this route.
    Dec 2011
    Quote Originally Posted by underthetire View Post
    The brochure showed three models. The base model has what looks to be a 5 station turret (for static tools only it looks like). The next model looks like it has milling capabilities, and the last model has c-axis control. Which one do you guys have?
    1. Need Help!- x3 startup suggestions needed asap
      By johnms88 in forum Benchtop Machines
      Last Post: 04-01-2011, 06:18 PM
    2. Brand Name Laser Machine Choices? Suggestions?
      By shaun091382 in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 03-04-2011, 11:02 PM
    3. Looking For A Job- Suggestions Needed
      By clint_so in forum Employment Opportunity
      Last Post: 02-16-2008, 12:29 AM
    4. Suggestions needed from cnczone
      By Jii Dee in forum DIY CNC Router Table Machines
      Last Post: 02-04-2008, 06:17 PM
    5. Suggestions needed
      By o4tuna in forum General Metal Working Machines
      Last Post: 07-16-2006, 05:12 PM
