I'd do a check on the lead screw to see if its really 5 TPI and not the metric nearly equivalent of 5mm per rev which is 0.19685" per turn versus the 5 TPI of 0.2000" - that would explain what your seeing.
Setup a dial indicator and turn the lead screw manually 5 turns -if its an inch on the nose then your 5 TPI , if its much less then its metric (0.984" or 16thou short).
Mike
LinkBack URL
About LinkBacks
