I have been using my homemade
CNC machine for almost a year now and I would like to make some minor modifications to improve its performance. When I originally built the machine, I was on a very limited (college) budget. I ended up opting for 5/8" drill rod (cheap O1 series from Enco) with plastic flanged sleeve bearings for the linear motion. Enco's website appears to be down at the moment, but the flanged sleeve bearings I am using are here (
Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies). The sleeve bearings are 5/8" ID and 3/4" OD with ~1" in length. While the machine works extremely well for light materials, I quickly notice the sloppy tolerances when I try to machine any harder materials such as aluminum. I feel that the cheap sleeve bearings are the culprit for this poor tolerance.
Can anyone suggest some good upgrades for the cheap sleeve bearings I linked to above? I have been looking at some oilite bronze sleeve bearings that seemed promising, but I have limited experience in this area.
It would be HUGELY beneficial for me if the OD stayed at 3/4" so I do not have to bore out the 12 holes I have to replace with larger sleeve bearings.
Oh and if you want to see any other details about the machine, this picture was from early on in the build process, but you should get the general idea
http://3.bp.blogspot.com/_UYb96Pphti...0/IMG_2113.JPG
Thanks!
