Results 1 to 2 of 2
Thread: building a CNC 3 axis Lathe
    Registered crob09's Avatar
    Dec 2010
    Exclamation building a CNC 3 axis Lathe
    I am in the process of building a CNC 3 axis lathe and have it almost comlplete, I will be posting a picture on my website soon and videos of the machine running along with my milling machine soon. what is a cnc
    I was wondering what i should do for a chuck, the motor I am using to turn the material has a strait shaft with a threaded hole on the end. It is out of a blower someone threw a rock in, I salvaged the motor for this project and now I am at the stage where I need a chuck.
    Any tips or ideas would be greatly appreciated.
    Jan 2006
    what is the arrangement of your 3 axes?
    Most lathes have a separate spindle machined to accept a common chuck mounting and mounted in high precision bearings. The motor is connected to this spindle through a gear train or most simply a belt and pullies.
    Matt
  1. Building Foam Lathe
    By hutch82 in forum CNC Wire Foam Cutter Machines
    Last Post: 08-11-2011, 08:29 PM
  2. Building a lathe for my XYZ- CNC
    By scheek in forum DIY CNC Router Table Machines
    Last Post: 03-08-2011, 09:57 PM
  3. Newbie- Building gingery lathe bed
    By slackwarerobert in forum General Metal Working Machines
    Last Post: 06-30-2010, 05:41 PM
  4. Building a mini lathe...
    By stag53 in forum Vertical Mill, Lathe Project Log
    Last Post: 03-24-2008, 11:22 AM
