basically if it is an outside radius such as a shoulder you add the tool radius to the .380 in your case making it 1.18mm or if it is an inside radius such as in a corner you subtract it. This would not work in your case because the insert radius is bigger than the .38mm radius.
LinkBack URL
About LinkBacks
