Results 1 to 6 of 6
Thread: Just a "compact" CNC machine with a mini-ATC
    Feb 2009
    Went to an amazing shop floor in Switzerland last week. These two machines and associated "automatic tool changers" were the highlight!
    First a "compact" spindle...
    Yes, I said Compact, see it there on the door! The "small" robot is the toolchanger for this machine...
    And from outside, a shot of the tooling rack for that robot:
    The other machine was the same CNC, but a different style toolchanger:
    Rows and Rows off $$$$$ tools - I bet they had $1-2 MM dollars in tooling on these machines - let alone the cost of the CNCs themselves and the robot/ATCs! Almost all the cutting tools were carbide TiAlN coated.
    And here is the "work pallet" storage for parts on the second machine. They said it can handle 2 ton slabs of incoming raw material, and for some parts works 24 hours non-stop to make the final machined part.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Mar 2006
    You mean they weren't making parts for Swiss watches? LOL
    Dick Z
    DZASTR
    Feb 2009
    Maybe a watch for Paul Bunyan!
    The company was Rychiger. They build machines. Their highest sales right now are for machines to fill the single use coffee containers for Nespresso.
    They also have literally TONS of coffee there for testing on the machines:
    That's a 1000 kg bag, and there are 20-30 more in the background...
    Registered pete from TN's Avatar
    Apr 2007
    Cool....
    Any idea what kind of tooling that is? Looks EXPENSIVE!! But hey man if you have the work for it, it is not expensive, it is NECESSARY!! haha peace
    Pete
    Aug 2008
    Several of the tools pictered were small straight shank collet holders (ER16?) held in what looked to be solid (set screw) HSK toolholders. Strange setup for such a high dollar operation.
    Joe
    Jul 2007
    Quote Originally Posted by scudzuki View Post
    Joe
    Do you mean the ones with the blue bodies? Those look like Tension/Compression tap holders.
    bob
    1. Need Help!- Dewalt DWP611 and Porter Cable 450 "Compact" Routers + Questions
      By Scheer in forum DIY CNC Router Table Machines
      Last Post: 12-27-2010, 06:24 AM
    2. Need Help!- Thread Milling using "C" axis no "Y" on the machine
      By tejano4life72 in forum Mori lathes
      Last Post: 07-19-2010, 03:59 PM
    3. Newbie- First Machine HELP...24"x36"x4" or Larger Setup w/ Gecko for under $3000
      By buschhoff in forum Want To Buy...Need help!
      Last Post: 03-20-2010, 07:37 PM
    4. New Machine Build- 24"X, 18"Y, 3"Z Steel Frame Desktop Machine
      By TLHarrell in forum DIY CNC Router Table Machines
      Last Post: 06-16-2009, 01:33 AM
    5. Newbie- Need CNC machine to cut .01" 302 full hard SS sheets (6" x 20")
      By Lowe in forum Want To Buy...Need help!
      Last Post: 03-23-2009, 01:58 PM
