Page 1 of 2 12 LastLast
Results 1 to 12 of 16
Thread: The most rigid 4-5 axis design
    Registered Zathras's Avatar
    Aug 2005
    australia
    Question The most rigid 4-5 axis design
    Guys,
    Eventually I would like to build a 5 axis CNC machine to mill Al alloys but a 4-axis will do for my purposes for now. I am aiming for maximum rigidity in the design with, of course, the largest working volume. Prob go for open loop stepper control.
    My Q is what is the most rigid type of design?
    This site has the most common design types;
    http://engraving.majosoft.com/html/body_choice.html
    But this is what I think is the best design;
    http://69.13.114.130/techspex/millin...illing_id=4041
    Thanks!!
    Gold Member mxtras's Avatar
    May 2005
    Can't see your second link.
    I think the most rigid design is like a planer mill where the table moves under a fixed bridge structure - the Y and Z and all other axis are mounted to the bridge. This style take up more room, but has the ability to be made more rigid than a moving column in my opinion.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Aug 2005
    australia
    Thanks for the reply.
    I'll try the link again;
    This is the Hermle c40U
    Some have described this as "trunion" type.
    Any one else care to comment?
    Jul 2005
    Aug 2005
    australia
    Thanks for the input and correct links guys.
    mxtras:
    I would have put it second on my list. Fair enough. You'd know better than me.
    You mean like the pic?;
    Attached Thumbnails Attached Thumbnails The most rigid 4-5 axis design-getimage.jpg
    May 2005
    I was refering to a bridge mill like this:
    http://www.xyzmachinetools.com/pages/money.html
    Scott
    Registered Evodyne's Avatar
    Dec 2004
    Question
    Hi guys! This has been on my mind lately too. I've pretty much decided to try this (all comments welcome).
    Sliding table under a fixed gantry. The table either is or incorporates a flat (horizontal) rotary table. The entire Y-axis raises and lowers as a Z axis. This is to combat the long moment arm from a conventional Z-axis with a rotating router. The router/spindle would rotate 180 degrees relative to Z so that the cutting tool can move from horizontal along the X axis to vertical and on around to pointing back along the X axis again.
    Anyone see any flaws or weaknesses?
    Evo
    Feb 2004
    hh
    Here's my gantry mill I'm building; it's taken a back seat while I forge ahead on my new lathe; but it is quite a bit more on than this pic
    If someone needs a more updated photo I'll shoot one
    Feb 2004
    hh
    Quote Originally Posted by Evodyne
    Evo
    Needs matched ballscrews and drive systems to work right and even then it's tough to make sure moton is matched end to end in Z
    May 2005
    Evodyne -
    I see no flaws with your logic. I used to run a massive Cincinnati that was configured the same way (with the exception of the pivoting head). I think this layout offers numerous advantages over a gantry - rigidity being one (for a bridge mill in general).
    I like the simplicity of Steve's design. I am envious!
    Scott
    Feb 2004
    hh
    more details of the mill; with the Z axis now
    rails are THK RSR25mm for Y and Z SR25 for X
    Travels are 21.375" X 14" Y 9.5 Z
    May 2005
    Nice and clean work, steve. I really like your work.
    Scott
  • Page 1 of 2 12 LastLast
