Old 07-31-2003, 02:15 PM
CactusChip is on a distinguished road
Spindle speeds for PCB milling
My mini-mill CNC conversion is just about done (wow, been saying that for a long time). I would like to be able to use it for milling the copper on PCBs. The maximum RPM is 2000. Is that sufficient? If not, then my next project will be a mini-mini mill stand for my dremel.
Old 07-31-2003, 03:31 PM
HuFlungDung's Avatar
Moderator
Hi Cactus,
Do ya like coffee? Because you'll have time for plenty of it with a 2000 rpm spindle
You will definitely want something much faster, especially for small cutters. You want light feeds and high speeds, to try to minimize burr buildup and tool clogging.
Old 07-31-2003, 03:59 PM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
I did some PCB boards using a 1/4HP trim router and If I remember at a feed rate of 4-8 IPM.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 07-31-2003, 08:03 PM
Okay, now to Plan B: I'll make a new mount that holds a trim router and bolts to the mill's head. I guess if I'm really lucky, I'll find a low profile model that I can trim down even further. It's not like I'll need much Z movement
Thanks for the replies. I had no idea what kind of RPMs I would need.
Old 08-01-2003, 04:45 AM
bunalmis's Avatar
bunalmis is on a distinguished road
My machine cutting copper of PCB spindle speed range 10000-30000 RPM.
You can see some PCB examples at my web.
www.geocities.com/cnc_designer/pcb.html
Cutting quality and feedrate proportional by the spindle speed.
Old 08-01-2003, 08:38 AM
ToyMaker's Avatar
ToyMaker is on a distinguished road
bunalmis:
That is impressive work. What tool do you use to cut your pcb's?
What does your PCB3 (with the TI TMS320 chip) do?
robotic regards,
Tom
Old 08-04-2003, 03:15 AM
bunalmis's Avatar
I made own cutting tool from 3 mm drill bits.
I give approx. 0.2 mm D form.
PCB3 controller board of my cnc.
So this is calculate the Step motor currents (microstep),
doing lineer interpolation and communicate with PC.
Old 08-04-2003, 09:20 AM
WOODKNACK's Avatar
WOODKNACK is on a distinguished road
Spindle speed
I have done some boards on my Taig mill. I have the spindle speed set to the fastest it will go. I cut this board at around 15 IMP. As you can see it came out nice. It matters on what kind of bit you have in it. Also did all the drilling too. It is very neat to watch it go!
My little piece of the web!
http://users.adelphia.net/~wjdupont
Old 08-04-2003, 09:59 AM
ToyMaker's Avatar
bunalmis, woodknack:
how do you lay out your boards: by hand or software?
robotic regards,
Tom
"Because a man thinks with his dick,
a woman dicks with his thinking."
Old 08-04-2003, 10:18 AM
WOODKNACK's Avatar
BY software. I have a friend that is right into it. He does them on some software. Ill ask him what he uses.
  #11   Ban this user!
Old 08-04-2003, 10:25 AM
bunalmis's Avatar
Re: Spindle speed
I draw by hand.
  #12   Ban this user!
Old 11-12-2003, 10:11 AM
NeoMiller is on a distinguished road
Can you please shed some light on the bits you guys are using for PCB milling. What should the end be like. Like an end mill, like a V or a round shape. If a V, then what should be the angle.
Sherline spindle to 30k RPM -- am I crazy? nicad General Metal Working Machines 21 11-17-2010 03:57 PM
Attn: Haas Techs/TL-1 SPINDLE SPEEDS DEAN Haas Mills 1 07-23-2005 02:07 AM
Spindle speeds and feedrate cap HuFlungDung OneCNC 11 07-05-2005 01:05 PM
Need max spindle speeds for metal bgolash General Metalwork Discussion 3 04-23-2005 09:15 PM
Speeds for a milling machine..how fast? bgolash General Metalwork Discussion 2 04-11-2005 03:20 PM
