Old 09-19-2005, 03:01 PM
bill south's Avatar
bill south is on a distinguished road
engraver tooling
I'm in the process (slow) of converting a lathemaster bench top mill for cnc application and will use it to machine colt type gun slides for custom sights and serrations. however, I would also like to use the same mill for engraving my shop logo onto the side of the slides. The materials I'll be working with are stainless and carbon steel. Is there a site where I could find tooling and informamtion for engraving??? I know very little about it but hopefully, it's a matter of proper tooling, speed and let the computer and mill do the work. Am I on the right track or as usual, out in left field.
billyjack
Old 09-20-2005, 06:57 AM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
You are definately on the right track. Use Cam to make your G code and I (who don't do engraving for a living but like to etch my parts as well) just use a #1 or 2 centerdrill as my toolbit. Generally speaking engraving like this is only about .005 deep.
10000 RPM 30IPM no problem.
www.integratedmechanical.ca
Old 09-20-2005, 11:01 AM
rustyolddo is on a distinguished road
Here's one link for you.
http://www.2linc.com/index.html
Old 09-20-2005, 12:22 PM
ViperTX is on a distinguished road
Great link rustyolddo.
Old 10-20-2006, 02:19 AM
guysmiley1980 is on a distinguished road
hi
i need to do letter engraving on steel.
my spindle speed max is 8000rpm
need to know wat should my feed cut be(ipm)?
the tip of the cutter can be 0.5
depth per cut is 0.01
anyway to make it faster
Old 10-20-2006, 02:48 AM
also can the depth per cut be more like 0.02 or 0.03
tip of cutter 0.5 to 1 mm
Old 06-19-2007, 07:08 AM
JWHISTON is on a distinguished road
gravostarusa.com
