Results 1 to 4 of 4
Thread: What is the part called that you put the R8 taper into the head of the mill?
    Registered Apples's Avatar
    Feb 2004
    Australia, Queensland
    What is the part called that you put the R8 taper into the head of the mill? Is that the spindle exactly? or is it something else.
    I'm trying to workout how hard it would be to make a rigid spindle that will accept standard sized tooling. I guess it is just two bearing, on at the top one at the bottom and then the spindle which I guess is hollow where the tapperd attachment goes into it.
    Can I just buy that part, because everything else in the head of the machine will just be a motor and belts???
    My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
    Jun 2007
    Spindle is what it is called.
    Jul 2007
    and no it isn't that easy...
    Jul 2010
    Belgium
    If you want to make yourself a spindle. you will get the best results with 2 angular contact bearings mounted back to back on the taper side and 1 normal bearing on the other side of the spindle.
    greetings
  1. Grizzly (G8688) 7x12 Head Stock Taper Bearings
    By Danny X in forum Mini Lathe
    Last Post: 05-27-2011, 05:05 AM
  2. taper in square part
    By larry53 in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 10-28-2009, 09:57 PM
  3. Need Help!- Turning a Thin part and Getting a Bad taper
    By JWB_Machining in forum General Metalwork Discussion
    Last Post: 02-26-2009, 10:26 PM
  4. Getting taper with Geo die head
    By Philip in forum CNC Swiss Screw Machines
    Last Post: 05-28-2008, 04:23 PM
  5. Taper Head Shoulder Torx Cap Screw
    By Smackre in forum Wood Working Tooling
    Last Post: 11-20-2006, 01:18 PM
