Results 1 to 3 of 3
Thread: 4th Axis info??
    Jul 2011
    Kanada
    4th Axis info??
    Ok, I heard rumors that there is a good thread on here somewhere about building a 4th axis for a milling machine. I'm thinking I would LOVE a spindle on my table... and then the thought occurred to somehow run the main tool with a servo motor so that I could tap holes... anyway, any input on the matter would be appreciated... especially if you can direct me to some good information. I did a bunch of searches but couldn't find anything.
    Cheers,
    Jul 2011
    Kanada
    Anyone?
    Apr 2004
    Oakland CA USA
    I don't think that's what a 4th axis does
    Usually, it's a fixture to hold your work that's set up sort of like a lathe on top of the mill bed, with a rotary table on one end and a tailstock on the other, the long axis between them parallel to X. The rotary table, equipped with planetary gears and a fairly low gear ratio, typically goes pretty slowly; it's not often fast enough to use as a lathe, with a fixed tool, but is typically used with rotary tools in the regular spindle, revolving the workpiece as it's carved on.
    It is possible to set up your mill's spindle with a servo and encoder to do rigid tapping, but that's another issue entirely. Most of us don't bother with it, and use spiral taps and a tapping head, like a Procunier or Tapmatic, which don't require synchrony between the spindle and the Z axis.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
  1. Need info on 4th axis for NM-135
    By tas99 in forum Novakon Systems
    Last Post: 02-18-2011, 09:19 PM
  2. 4th axis info wanted.
    By two4tom in forum Tormach Personal CNC Mill
    Last Post: 09-14-2010, 12:56 PM
  3. GMR cnc 5 axis w/ Fagor controler info?
    By Jim Brown in forum CNCzone Club House
    Last Post: 12-20-2009, 08:12 AM
  4. C Axis info
    By Koalas in forum Fanuc
    Last Post: 03-12-2009, 02:41 AM
  5. need info on 4 axis machining
    By greggv in forum General Metal Working Machines
    Last Post: 02-18-2005, 01:08 AM
