Old 08-27-2005, 12:26 PM
tminionman is on a distinguished road
Purchase dilemma: 4th mill axis or Lathe?
I'm looking to buy a mill and/or a lathe with all the trimmings to make myself a home metalworking shop. Buying the lathe and mill from lathemaster.com and the accessories form sites such as enco.com will cost upwards of $4000. Because this is such an expensive endeavor, I'm lookign intomaking a 4th axis for the mill so I don't have to buy two tools.
I suspect the easiet way to dio this would be to use a combination of rotary table (with a worm gear drive) and spin index (direct hand drive) such as this one http://www.penntoolco.com/catalog/pr...categoryID=352. This way, you could use the worm gear drive to get precise movements on the rotary axis. to simply remove material en masse, you could disengage the worm gear and use the hand crank to turn the workpiece. This way you don't wear out the worm drive turning the table many revolutions.
Can a rotary table handle this kind of load (with tailstock, of course)?
Is such a thing pratcical to do lathe operations such as machining straight shafts and tapers?
I appreciate any help you guys can provide.
