Basicly the shape you want is the die you will require.
You may get lucky by squeezing a round section of stock in a square die, but the problem will be where is the weld in the tube and the bend or squeeze rate will change and leave less than a uniform shape.
You will have to make dies and if the change is too radical to do in one step you may need 2 or more sets to gradually form the shape you require.
This is what I call seat of your pants engineering, trial and error will in time lead you to what you want to obtain.
Ark1.
LinkBack URL
About LinkBacks
