Old 04-06-2011, 01:53 PM
quasarix is on a distinguished road
Weird old communications port!
Greetings!
My friend has an old MAHO 900 Milling machine and it has weird communication port, so it would been cool if someone have schematics how to rewire that port to RS 232 if its possible.
Here are pictures of port:
Old 04-06-2011, 02:41 PM
Al_The_Man's Avatar
Looks like a centronics printer port socket?
Possibly parallel punch?
Old 04-06-2011, 05:59 PM
John Bennett is on a distinguished road
You might want to remove the plug and see how many wires are attached as this looks like a plug that someone has added to connect a cable up to. I say this because the picture shows "slot" screws and most German made machines have "philips" screws. As Al stated it looks like a centronics printer port socket. A quick search shows that most of the unit models use RS232 (serial) communication , and the original plug may not have been as easy to find as the install replacement. If you have the wiring diagram or manual, maybe we can help further. If not, search for like model and ask owner for info.
Old 04-06-2011, 06:11 PM
What did we use in the "old days" for portable tape punch connections? Or am I the only one blessed with a Flexowriter. Some sort of alphabet soup like EIA TTY ESA ETC. LOL
Dick Z
DZASTR
Old 04-06-2011, 06:20 PM
neilw20's Avatar
neilw20 is on a distinguished road
How many pins?
That's a 24 way connector.
The centronics is a 36 way with same style shell.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
HELP with dragon cut serial port communications landmark CNC Plasma and Waterjet Machines 1 09-12-2010 06:27 PM
Need Help!- Communications JOHN PARSONS Want To Buy...Need help! 0 07-07-2010 04:43 PM
I need help with communications peterpan3 Mazak, Mitsubishi, Mazatrol 6 03-24-2009 06:44 AM
Paraller Port Driver - Breakout Port billy General Electronics Discussion 7 11-20-2008 07:27 AM
Communications output to Printer Port kheri Post Processors for MC 0 03-26-2005 12:40 AM
