Old 04-04-2011, 10:49 AM
Jay Kyle is on a distinguished road
Bridgeport Vs Birmingham CNC Mill
Hello,
I have an opportunity to purchase either an older Bridgeport Series 2 Interact 2 or a Birmingham B2VS CNC mill. The table envelope is the same (near enough), but the Birmingham tops out at ~5100 RPM and the Bridgeport at ~3500 RPM. I plan to work on smaller parts so thinking the higher RPM is a pretty strong deciding factor.
Both are about the same price so that's not a factor.
Any thoughts?
Jay
Old 04-04-2011, 04:56 PM
This is a personal OPINION. My impression of Birmingham machinery is severely tainted.
I had the occasion to operate a Birmingham 14X60 (approx.) lathe.
It was labeled "Hardened ground gears". Gears ate themselves into useless mush in 6 weeks.
The 4-way tool post was located by a pin directly into a hole in the cast iron base, no hardened bushing as is typical. The hole wore out and the turret would turn when tool pressure was exerted.
The foot operated brake constantly required re-adjusting in order to stop the spindle.
It had the wrong belt installed on the oil pump when delivered, way too loose.
The work light blew the fuse every time it was turned on.
Needless to say, bad first impression.
Is Birmingham a trading company name? that sells machines from different manufacturers? from different sources for components? That is my impression.
Would I personally purchase any Birmingham machinery after that experience?
*##@@@NO!!!!!
Dick Z
add: I forgot, the half nut was soft brass and was not usable by six weeks after installation. The lever to engage cross feed could easily be engaged with long. feed resulting in unwanted tool "diving" into work. This then would turn aforementioned square turret to rotate and add to the problem. To disengage, lead hammer applied to handle worked fine. DZ
DZASTR
Old 04-07-2011, 12:15 AM
Thanks Dick, I took your advise and bought the Bridgeport! I'm excited!
Jay
Need Help!- Parts for Birmingham Mill wdp67 General Metal Working Machines 0 09-18-2009 09:15 PM
gmc or birmingham mill rppman Knee Vertical Mills 3 08-30-2009 04:34 AM
Malcolm in Birmingham Malc in Brum Europe Club House 2 09-03-2008 05:13 PM
Birmingham AL area swampbilly Mentors & Apprentice Locator 0 11-15-2007 05:59 PM
PM, GMC, Birmingham, MMX or Jet lathe? Rickady General Metal Working Machines 6 10-21-2006 02:43 PM
