Old 04-01-2011, 06:13 PM
Spud76 is on a distinguished road
SuperMax YCM-16VS
Has anyone with one of these had to replace the ball screws? I'm wondering if there is something other than going to Supermax and getting bent over with the cost. I would not have a problem doing the machine work to make it happen. I have experience with taking ball screw shafting and annealing the ends and machining ends to what is needed. My concern was the nut assembly clearance on the X axis. I looked at Roton and thought about using two nuts back to back to adjust the backlash. Has anyone played with something like this? Thanks, Dave
Tags
supermax, ycm-16vs
Supermax YCM-16VS Re-retrofit/Upgrade macona Vertical Mill, Lathe Project Log 25 12-03-2011 06:29 PM
Yci Supermax krustykrab Hard and High Speed Machining 4 10-17-2011 08:56 PM
supermax ycm-16vs manual available rolfinator2002 Knee Vertical Mills 3 09-02-2011 12:41 PM
Need Help!- SuperMax ycm-40 smorris Knee Vertical Mills 5 05-05-2010 09:22 AM
SuperMax ycm 40 Tymco Knee Vertical Mills 0 07-23-2007 09:46 PM
