Old 03-31-2011, 02:58 PM
Scottjit is on a distinguished road
Thumbs down MITSUBISHI MH-4A HORIZONTAL MACHINING CENTER
We just bough and moved in a MITSUBISHI MH-4A HORIZONTAL MACHINING CENTER. Trying to get it running. There is a constant air blow in the spindle, is this normal? The tool air blow does work and turn on and off. There are also two wires that run inside of a pipe on the bottom side of the spindle. They are not plugged into anything? Where do they go and are they related to the spindle air leak?
Thanks,
Scott
Tags
mh-4a, mitsubishi
Need Help!- Manual CNC Mitsubishi machining Center wanchai101 Mazak, Mitsubishi, Mazatrol 1 02-26-2010 01:15 AM
CINCINNATE HORIZONTAL MACHINING CENTER MODEL AT r.2.d.2 Cincinnati CNC 9 02-12-2010 06:56 PM
Syil X4 and horizontal machining cvafiadis Syil Products 7 11-13-2008 07:06 PM
Need Help!- Horizontal Machining Centers BaronMachine Haas Mills 4 02-06-2008 08:45 AM
new to cnc machining center BruceinOZ CNC Machining Centers 6 08-11-2007 01:25 PM
