The problem you'll have is the delta between adjacent depths....in other words if you're cutting at the 10 inch z-axis and the next cut can't be at the 1inch depth unless you've moved in the x or y-axis a distance equal to 1/2 the width of your spindle and any supporting structure.
LinkBack URL
About LinkBacks
