Old 03-16-2011, 08:21 PM
blake374 is on a distinguished road
Innacurate cuts! Please help!
Hello (please don't move thread)
I just finished building a 4 axis foam cutter. It is a belt driven machine with two x and y axis's with a wire in between them. When I cut out 4 boards out of a block of foam I am getting a strange pattern. one half of the pattern appears to be slightly off. Attached is an exagerated pic of the cut pattern and one half of the machine.
The cut is going from left to right and cutting out the center first and then returning on the outside. The pattern also appears the same on both sides of the foam block. This leads me to believe it is an issue with both sides of the machine.
The only things I can think of is the y tower out of allignment or unlevel. Or the belt that drives the y axis is at an angle from the pulley to the y carriage.
If anyone can offer any insight that would be great.
Blake
ID:	129242   Click image for larger version
Name:	Cut pattern.PNG‎
frustration....plasma cuts off during cuts any ideas? gpnjuice CNC Plasma and Waterjet Machines 2 11-18-2007 06:45 PM
which cnc package cuts 2D parts with least extraneous cuts? mbwittig General CNC (Mill and Lathe) Control Software (NC) 3 05-06-2007 06:29 PM
More first cuts CNCadmin DIY-CNC Router Table Machines 0 11-27-2006 10:00 AM
More first cuts wcarrothers1 DIY-CNC Router Table Machines 4 11-25-2006 07:19 AM
First cuts wcarrothers1 DIY-CNC Router Table Machines 7 10-27-2006 11:17 AM
