Old 03-15-2011, 12:10 PM
Garp is on a distinguished road
What machine is this??
Hi there,
I have this nifty little mill that is used for fabbing up prototype parts, machining revisions and otherwise working our product prototypes prior to manufacture. It runs off of ooooold Mach3 software but I cannot find any Identifying information on the unit as to what it is or who makes it. If anyone knows what make and model it is I would greatly appreciate finding out.
I just use Gcode with Mach3 to mill with it. I have been using it to mill screw holes in pistol grips on the side, but would also like to get to where I could machine the whole grip on this machine. Any information to that end would also be appreciated.
Garp
Old 03-15-2011, 12:16 PM
Al_The_Man's Avatar
There are quite a few Mini-mills like that now that come from R.O.C., it's similar to a Sherline.
Why do you need to know the make? There is not much to them.
Old 03-15-2011, 12:20 PM
Hi Al,
The main reason is personal interest in knowing the tool I am working with. It does work fine and hasn't ever broken, but Im sure some day it will and I'll need to order something to fix it.
Old 03-15-2011, 01:01 PM
Al_The_Man's Avatar
Well if you find out it is an import, you may be out of luck for parts, most importers do not find it worth while, especially on the miniature type.
But as in your case it shouldn't be a problem getting something 3rd party or custom made if something goes?
Old 03-15-2011, 01:50 PM
mactec54 is on a distinguished road
Garp
I think you will find it if you Google Maxnc, they have been around for a long time & made in the US
Mactec54
Old 03-15-2011, 04:17 PM
maxNC it is ! They show markings on their site, but there's none on the one I got. THANKS!
Old 03-19-2011, 07:24 AM
Fixittt is on a distinguished road
its a maxnc 10 1/4-20 acme screws
some tips, make sure to lube the screws and ways and adjust the gibs alot!!!
saleCNC laser engraving machine and CNC woodworking machine zhangrui1588 Laser Engraving & Cutting Machines 3 05-08-2011 03:54 PM
cnc router/CO2 laser machine/cnc plasma cutting machine cncengraver Chinese Machines 0 06-25-2010 09:48 PM
Need Help!- Hardinge CBN Turning Machine with GE Fanuc Machine Model CS- 51, S.No. CL – 622 -BSP M.RISHIKESH Hardinge Lathes 1 11-20-2009 06:03 PM
Deep Groove Taig machine would it be a good starter machine Fritzie15 Taig Mills & Lathes 0 09-20-2007 09:37 PM
