Old 03-13-2011, 05:02 PM
S3MIH3MI's Avatar
S3MIH3MI is on a distinguished road
TL521ER Purchase/Review.
After the purchase of the TL mill I read some older post of peoples opinions.
Without trying it, they were only opinions but had I read them prier to the purchase I may not have bought the TL CNC mill. So now that I have had the mill for almost 3 months and got used to it, I have an opinion.
I first would like to say that I am not a tool maker by trade but I am an electrician. I have been using a small mill and lathe from Princess Auto for the last 2-1/2 years.
Do to the size of the table there were many limitations and my next machine was going to have a larger table. I decided to go CNC after watching my brother running his.
Let me say that my brother has been a licensed tool maker for over 30 years. He owns a 3 phase CNC with a 48 inch table. I’m not sure what make it is but it has a computer of its own and came from a tool shop.
I had him check out the specs on E-Bay before I purchased it.
Now for my opinion of this bench top CNC.
Price was fair to good
Shipping was ok but they hit me with $400 broker fees
Packaging was very good (2 pieces both in wooded boxes and strapped)
Setup was plug and play (3 hours and I was cutting)
Issues with this machine were minimal and mostly operator influenced.
Speed control only had 2 speeds. Alex sent a new one that day and I had it in a week.
The spindle motor could be of better quality but does the job.
Stepper motors don’t look like much but they are smooth and quiet. I did find out that with these stepper motors, high speed milling is out of the question. They lose too much torque at higher speeds.
Accuracy is as stated on E-Bay. And yes the table is a cast table from China but he claims the ways are hand ground. The full travel is smooth with no tight spots.
The controller is very clean looking and does not even get warm after hours of use. Stepper motors plug in using RJ45 plugs.
To sum it up. My brother was very impressed with the machine. Especially the “Z” axis (3 linear bearings).
He was so impressed he had to bring another tool maker from work to watch it in action. And with the large table, I can use a real milling vice.
All in all, I don’t regret this purchase and would do it again in a heart beat.
I can't compare to any of the other small cnc machines but table size does matter.
Here is a short video with a 3/8 end mill.
Note: This is the first time I used a 3/8 end mill.
Because it is pushing the limits of the machine, I will stick to 1/4" and smaller
http://home.cogeco.ca/~fileme/vids/TL5521.wmv
Here is another with a 1/4 HSS end mill
Here is an example of the accuracy of the machine. I wanted to have two bearings press fitted into the side of the crankcase.
Below is the bearing sitting on top edging into the hole.
This was pressed in by a 12 ton press. Not that I needed 12 ton. LOL
Old 03-14-2011, 12:07 PM
S3MIH3MI's Avatar
OK I took some advice over at HMEM forums. I made a few changes but kept the
feed rate and cut depth the same.
Big difference with the same 3/8 cutter.
http://home.cogeco.ca/~fileme/vids/TL521b.wmv
Review of purchase from Modular CNC (New Mexico) Pawelski Vendor Discussion 11 02-07-2012 05:27 PM
pre purchase Patriot review gearhead dan Shopmaster/Shoptask 5 10-21-2009 10:59 AM
I need to review MBG General Metalwork Discussion 15 03-07-2008 02:57 PM
