Old 03-11-2011, 03:57 PM
rnr107's Avatar
rnr107 is on a distinguished road
Mach3 Write wizard bug?
Hi all,
I found something strange happening with the text wizard of Mach3:
If you type "OTO" all capital and choose "Times New Roman" font
the spacing between the first "O" and the "T" does not exist, but the spacing between the "T" and the second "O" is fine, and therefore a part of the first "O" gets over-writen by the "T"...
Any solution around that?
Ta,
RNR
Old 03-11-2011, 06:34 PM
ger21's Avatar
Set the separation to 100
Old 03-12-2011, 02:48 AM
rnr107's Avatar
Hi Gerry,
Thank you for the reply.
Yes, I could set it to 100, the T wont overlap the O anymore. But the spacing still shorter. It doesn't looks right.
Is it a bug?
Laurent
Old 03-12-2011, 04:55 AM
ger21's Avatar
OK, I see what you mean, that it's not centered between the O's.
Whether it's a bug or not, would probably depend on who you ask. I don't think it takes into account which letters are adjacent to each other to vary the spacing,but just uses a generic spacing between all the letters.
Regardless, you're stuck with it the way it is. The wizards included with Mach3 were all donated by users. The Write wizard was added many years ago. It's by far the most complex wizard included with mach3, with thousands of lines of code.
Mach 3 write wizard Jig Maker Engraving Machines 5 03-02-2011 12:14 PM
Write Wizard Help! ibuildstuff4u Mach Wizards, Macros, & Addons 4 08-12-2009 12:25 AM
Write wizard...To many numbers Scott_M Mach Wizards, Macros, & Addons 0 02-09-2007 12:14 PM
Mach 3 Write Wizard rweatherly Mach Wizards, Macros, & Addons 2 12-18-2005 04:25 PM
Write Wizard Problem rweatherly Mach Wizards, Macros, & Addons 1 11-13-2005 07:17 AM
