Old 03-09-2011, 02:50 PM
zarl is on a distinguished road
Home/overtravel problem on Feeler Fanuc Oi-Mc
Hi all
I have problem with homing y axis on Feeler milling center.
Its Fanuc Oi-Mc.
When we try home y axis, it go in overtravel.
Reset by pressing can+P during startup doesent help ;(
We never had this problem before.
Can the encoder be faulty in this way ?
When i try manually press the home/endstroke swich for x,
The control write "emergency stop"
But when i press same switch for y axis, nothing happen on the control.
Does this mean this switch is faulty ?
Any help is very velcome Thanks
Old 03-09-2011, 08:56 PM
rambo77 is on a distinguished road
Which over travel alarm number is it? 500 to 505 are software overtravels. CAN+P on start up should disable the soft overtravels.
When you get the overtravel alarm, check DGN 301, this is the axis position with out the decimal. Compare the position to the over travel limits set in parameters 1320 (+ direction) and 1321 (- direction). Parameters 1322 & 1323 for 2nd overtravel; 1323 & 1325 for 3rd overtravel. The 2nd & 3rd overtravels are turned on and off by G codes.
Alarm 506 & 507 are hardware overtravels, meaning something has tripped the switch.
Hope this helps. Rambo
Old 03-10-2011, 03:33 AM
Thanks for answering.
It was the deacceleration/endstroke switch, it was broken inside, and full of water
Need Help!- Home Position problem Hitachi Seiki Fanuc 11M diegojulio CNC Machining Centers 7 04-26-2010 07:52 AM
Build Thread- Fanuc OT parameter for Feeler FCNC-100 shujah Fanuc 1 10-23-2009 12:22 AM
Need Help!- Fanuc OT parameter for Feeler FCNC shujah Bridgeport and Hardinge Mills 0 10-19-2009 11:17 PM
Femco lathe, Fanuc OT overtravel problem acerocket Fanuc 4 04-15-2008 05:48 PM
Need Help!- Overtravel Problem mbpp Fanuc 4 04-12-2008 10:30 PM
