Old 03-09-2011, 07:12 AM
PVO PVO is offline
PVO is on a distinguished road
Choosing the right manual lathe and mill
I was wondering if any of you can help me in my search for a used manual lathe and mill? I want to use the machines for making motorcycle parts. I don't need anything too big maybe an 11" x 36" lathe. I don't have a real big budget. I'm looking to spend $3000 tops on each piece of machinery but machines in the $2000 range would be more desirable. The majority of the work would include, machining two stroke cylinder heads, crank and wrist pins, making spacers, bushings, triple trees, jigs, fixtures, rear sets, etc. I've seen some old South Bend and Sheldon lathes in this price range. How is parts availability for these machines? Are they any good? What kind of speed range should I look at? I'd be interested in turning a small amount of titanium. I'd also like to have the ability to cut metric threads. I know I may not be able to get all these features out of one machine but these are the initial guidelines of come up with. Can any of you give me an idea of what to look for or offer some advice? Thanks.
Old 03-10-2011, 09:47 PM
Ed from NY is on a distinguished road
There is an oversupply of machinery and you may be able to find old American iron in reasonably good condition in the range you are looking for. Try to find it locally where you can examine it and see the kind of place it has been used in. Make sure the mill has a DRO and that there is no excessive wear in the ways of the mill or lathe, otherwise give it a pass. Good luck!
Old 03-12-2011, 12:44 PM
JimBoyce is on a distinguished road
When inspecting a machine, run the slides to the ends. If they get tight it indicates wear the heavy use area. Your budget should get you some nice machines.
Old 03-12-2011, 05:26 PM
PVO PVO is offline
Thanks for the info so far. What components should be inspected when looking at used lathes? How much play should I look for/what is acceptable?
Need help choosing bar lathe I think? houdini Want To Buy...Need help! 5 05-28-2009 03:49 PM
Help choosing lathe dannirr Mini Lathe 4 04-13-2008 06:01 AM
Need help choosing a CNC lathe K. R.Giridharan General Metal Working Machines 0 08-14-2005 04:23 AM
NEED HELP Choosing A Lathe InventIt General Metal Working Machines 0 11-21-2003 05:28 PM
Choosing a Sherline mill or lathe kdoney Benchtop Machines 0 04-19-2003 10:36 AM
