Old 03-04-2011, 11:13 PM
KosmiK is on a distinguished road
Tired of opening the door.
I am currently opening the door on my NL 2000 Lathe to manually oil my roll tap with a small brush. Can anyone direct me to some kind of automatic oil injector either for the hole or the tap?
Old 03-06-2011, 07:20 AM
PixMan is on a distinguished road
Actually, you shouldn't need to use a different lube for the tap. What coolant are you using in the machine now? Can you use a 10% concentration of it if it's a semi-synthetic of full synthetic? I have used roll form taps for a number of years now with just the coolant. I get a few less holes per tap this way, but the time savings of no having to stand there and lubricate the tap for every cycle is well worth the increased cost of the tooling.
So what material, which taps and what size drilled hole do you have to work with?
Old 03-06-2011, 10:26 AM
I have tried just using the coolant and we get maybe 50 parts before it breaks.
I have not tried increasing the coolant concentration. we are running about 5%.
greasing the tap manually we can get 500 to 1000 parts.
the material is 316 sst stainless and the hole is 10-24 unc.
Old 03-06-2011, 12:09 PM
OK, so just out of curiosity, tell me if you can: What tap (be specific about brand and cat no.) are you using, how deep is the thread, and is it a blind hole or through hole?
I would like to run this through the Walter Titex/Prototyp "CCS" software to see what it comes up with. There are a number of good taps with "hardlube" type of coatings made just for this situation. Yes they are a lot more money than a run-of-the-mill uncoated Balax Thredfloer, but wow, what a difference in performance.
Old 03-06-2011, 08:20 PM
fizzissist's Avatar
fizzissist is on a distinguished road
From my experience tapping blind 0-80s in 304 with a roll tap, a little lube goes a real long way, especially when you can't afford to break a tap in a very expensive and limited run part.
One thing you might consider, if possible with your controller, is a little air burst application of some oil by a system separate from the regular coolant, like a mister. Most controls have two coolant on/off G-codes, like M7 and M8.
You're using M7 for coolant? wire your mister with a solenoid into the M8 port or plug, and just command it on and then right off in the next line to have it spurt a little goop on the tap.
I generally do it by hand, and it's a PITA, but....not that many holes. For real production, I'd set up something on auto.
...I found Emuge to be a great product, and tech support is tremendous! OSG is my next choice.
(Another cheat is to push the tap drill size as much as you can get away with, and sometimes a metric drill does the trick!)
Old 03-06-2011, 09:35 PM
underthetire is on a distinguished road
All good suggestions, but there is a cheap, simple effective way to lube your tap. Mount a hampster water bottle with tapping fluid somewhere you can reach with the tap. Had customers do this many times, works well, and your only in to it for about ten bucks.
Old 03-07-2011, 03:28 PM
I am using a Dormer MTT-x UNC HSS -XS1
EO29 10-24 2B EN -40.
Thanks for all the suggestions.
I actually just bought a pet Rat for my kids on the weekend and I can see the potential in the hamster water bottle.
Old 06-22-2011, 12:00 PM
Well I have made the hamster tap oiler and it works like a charm. I have a video of the operation here.
YouTube - ‪Auto Tap Oiler‬‏
Old 06-22-2011, 07:34 PM
Delw is on a distinguished road
KosmiK
that vid is a crack up nice job.
Also what works well is a chunk of bees wax mounted on the table of a mill. spin the tap into it and then tap small holes. works great even a candle works
Delw
Old 06-22-2011, 11:05 PM
Hey,
Thanks for the tip.
Need Help!- Old, tired and confused... Buzzwerk Haas Mills 6 08-30-2010 02:10 PM
Need Help!- Old, tired and confused... Buzzwerk General Metalwork Discussion 1 08-23-2010 03:15 PM
Production Work Needed - EDM, Milling, Grinding *door to door free shipping* FreedomTechUsa Product Announcements & Manufacturer News 0 03-11-2010 10:30 AM
Moving a Prototrak mill under a garage door opening kentucker237 General Metal Working Machines 12 02-18-2009 10:07 PM
Door Not Opening WASLYH Fanuc 5 10-31-2007 03:09 PM
