Old 02-28-2011, 10:53 AM
dsdmax is on a distinguished road
G0602 - Rolle Dad's bed alignment
I am really struggling with this - i chucked up a 1/2" diameter ground rod and followed the steps for horizontal alignment. After recording the high and low points and averaging them close to the chuck (about and 1") and far (about 12") i determined i needed to add some shims. There is the problem - i am using brass shim stock (thought that would be better than paper). No matter how much i add my measurements are not changing.
Does this method work on the larger lathes? i am thinking that maybe there is too much mass in the iron and it is not flexing?
Has anyone else been successfully with Rolle Dad's on the G0602?
How important is it to perfectly level the lathe before starting?
Old 02-28-2011, 03:05 PM
Russ Kaiser is on a distinguished road
I am guessing your lathe, being relatively short and relatively light, does not have mass sufficient to produce any noticeable torsional flex when one mount is shimmed up. The important leveling at this point is getting the ways level in both directions, shims should work for that.
Are you measuring a significant alignment error? Alignment error may not be due to being out of level, the head could just be misaligned with the ways.
Rollie's Dad's Method (RDM) for Mill/Lathe Alignment Vogavt Benchtop Machines 9 11-21-2011 10:22 AM
Need help with G0602 lubrication T_Tactical Benchtop Machines 10 01-21-2011 10:16 PM
G0602 3 jaw chuck tmbg Benchtop Machines 9 11-15-2010 01:15 PM
G0602 eartaker Benchtop Machines 5 08-20-2010 03:35 PM
G0602 Flex rwskinner General Metal Working Machines 0 01-22-2009 06:58 AM
