Old 02-23-2011, 02:43 PM
DragonRider is on a distinguished road
HS VA-50 ATC
Hs va-50 atc
Hi Guys, I'm hoping to get some clarifcation on a reply in this form."(2. May be the parameter on Micon8 was lost. you must put it into by chosing mode 40 on Micon 8 keyboard and "turn on the contact paramerter on."
On keyboard of micon8:
40 input
01 inp 01 inp and then put [CLR]
the same 01 inp 02 inp and then put [CLR]
to 25 tool number or the top tool of machine.
after key in OK. Turn contact on micon8 off.)" I don't know where the contact parameter is located? And I don't have the MTB manual.
If it starts on pot 01 it will do correct call outs up to pot 20, then when I call for pot 01 again, it does (12) rotations before it stops, sometimes on pot 5 or 9 or ... and thinks it's pot 01 and the cycle starts over.The Seicos Micron 8 controler knows tool 21 is still in the spindle.It worked correctly when I got it,but I had a power outage.Anyway I hope someone can help.Thanks in advance Dave I've posted a pic of the Address/ Data keyboard that I've only been able to half way decipher,sure would like to be able to understand it 100%.
