Old 02-17-2011, 09:48 AM
vandl is on a distinguished road
Weidemann C2000q Reference Problem
I have a Weidemann C2000q CNC punch with Fanuc Op-B controller. When referencing the machine will set both X and Y axises (or at least it appears on the display that the position is correct) but then nothing happens. Usually it would ref X then Y and then turret and then auto-index station. Has any one any information on what the machine checks in order for it to complete the Zero Set routine so I can narrow down where the fault may be. There has perhaps been an issue with low temperatures and referencing in the past but this should be affecting it now. Any suggestions at all would be greatly appreciated. Thanks in advance.
Tags
fanuc, reference, temperature, weidemann, wiedemann
5t reference problem bigalow 5T/5M 3 04-16-2012 08:54 PM
Need Help!- Weidemann C2000q Reference Problem vandl General Metal Working Machines 0 02-16-2011 07:13 AM
Need Help!- G&L Ram630 X Axis Reference Problem bruno69 CNC Machining Centers 0 01-12-2011 11:01 PM
Bridgeport Haidenhain Traverse Reference Problem wahidbashir Bridgeport and Hardinge Mills 9 01-25-2010 10:29 PM
Need Help!- Fanuc21i-T - Reference point problem Dare Fanuc 6 01-22-2009 04:04 PM
