Old 02-15-2011, 02:11 PM
jheal4 is on a distinguished road
ID Chucking Brass with No Marks
Hey Guys.
I have a Brass Casting that needs to be turned on both faces and the OD. The ID is approximately 4" (has a 1 degree draft angle though).
I was going to just use an ID chuck (with steps so I can do the back face), but have been told that no chucking marks are allowed (which makes no sense since its a crappy cast finish anyways). I know that if I chuck this internally we will be getting marks, at least with any jaws that I can think of. The cast tolerance is also to large for any decent fitting mandrill.
I have a sample here and I cannot even figure out how it was made (no witness marks anywhere).
If anyone has any suggestions please let me know.
Jordan
Old 02-15-2011, 04:57 PM
*Registered*
TheBigJW is on a distinguished road
Originally Posted by jheal4 View Post
Hey Guys.
Jordan
Soft pie jaws?
John
Old 02-15-2011, 05:21 PM
Techman-10 is on a distinguished road
Exclamation
How about using a Faceplate? Also you can use a 3 jaw with padding and take small cuts. I have in the past used small rubber squares and chucked it up tight enough to hold.....another words don't wrench down on the part. I don't like to recomend the following but I have seen people use a large live center and trap the part between the Live center and a Face plate or chuck. I know it is a super but if done right it will work and take small cuts....
Old 02-16-2011, 03:23 AM
H.A.S. is on a distinguished road
Think I would use a 3 or 4 jaw with aluminum spacers taped to the jaws. Maybe make a plug, and use the tailstock lightly for a little more support. Doesn't sound like you'll be taking off much per pass.
Problem- Nexus 250 Chucking direction 250my Mazak, Mitsubishi, Mazatrol 3 03-25-2010 01:34 AM
New Guy with Chucking Reamer Questions MetalShavings Benchtop Machines 2 12-28-2009 06:47 PM
Chucking on Tapered Hex Tazzer General Metalwork Discussion 1 01-17-2009 07:18 PM
spline chucking reachraghu Work Fixtures and Hold-Down Solutions 7 04-09-2007 03:14 PM
Polishing tooling marks from brass? saturnnights General Metalwork Discussion 2 03-31-2006 10:12 AM
