Old 02-09-2011, 07:54 PM
erkiwi is on a distinguished road
Smile Spindle bearings
Hi.
I am making a new spindle for my small CNC machine,I have a Er32 collect chuck with a 20mm Dia.sharft 150mm long which will be running at 4000rpm max 600rpm.Can I use sealed deep groove ball bearings which are rated to10,000rpm in the sharft housing or do I need to use angular contact bearings.Also if I use deep groove ball bearings is there any advantage in having two back to back at the bottom and one at the top of the housing?
regards Eric
Old 02-10-2011, 10:07 AM
Deep groove bearings have axial clearance. Consequently, they have end play. If that is acceptable for your spindle, they will work.
Deep groove bearings have limited axial thrust capacity. If your spindle has to absorb low thrust loads they should work.
Personally, I would use sealed angular contact bearings. I have recently incorporated them in two different spindle designs.
They are hard to find and pretty expensive. I located these at GMN bearings. Others have them in their catalogs but do not keep them in stock. Our clients can not wait 6 months for replacements if they have a "crash".
Dick Z
DZASTR
Uh Oh BMC-20 spindle bearings? fasto HURCO 4 12-20-2010 09:33 PM
Spindle bearings RKR Fadal 11 09-15-2010 07:44 PM
How to tell if the spindle bearings are bad? JMFabrications Haas Mills 9 05-19-2008 05:01 PM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 02:49 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
