Old 02-04-2011, 06:14 AM
Oviksnc is on a distinguished road
Blockwise transfer to TNC355, max amount of blocks?
Hi..
I´m just wondering how many blocks you actually can transfer to the machine via drip feed?
I remebered i read something about 65xxx blocks stated by Heidenhain. Is this correct? I thought it was unlimited due to the erase of the earlier blocks.
I made a program from Rhino 4.0 with madcam software and this program is 85300 blocks. It would be great to know if this is possible to run before i start
Machine is Mikron WF71 with TNC355 controller.
Thanks.
/Johan.
OviksNC/Sweden.
Old 02-06-2011, 04:28 PM
Fatty is on a distinguished road
I run a tnc355 with drip feed, have run over 150000 lines of code, although if it stops the read out on the screen doesn't give correct line number. Not sure what it is, 65000 then possibly restarts from zero. Worth checking the code before sending, mine ocasionally starts a line with out a line number so I import the code into Excel and data sort, this leave spurious code at the bottom. You can search for it and delete/adjust as required. James
Old 02-07-2011, 12:25 AM
Hi.. Yes i ran the program and it worked just fine, for me it looks like the 355 counts 999 lines and then begins from 0 again.
Thank you for the input.
/Johan.
OviksNC/Sweden.
Problem- Heidenhain TNC355 postprocessor vasyl markiv SolidCam 21 04-09-2012 03:54 PM
Need Helical Interpolation example for Heidenhain TNC355 soweebee Bridgeport and Hardinge Mills 4 03-14-2012 07:36 AM
Newbie- Mastercam X2 postprocessor Heidenhain TNC355 Glitter Post Processor Files 0 09-29-2008 10:09 AM
Need Help!- Blockwise transfer,drip feed on Tnc 2500. Paul cs Bridgeport and Hardinge Mills 1 09-02-2008 08:45 AM
Heidenhain TNC355 Machineguy General CNC (Mill and Lathe) Control Software (NC) 4 11-28-2005 02:42 PM
