Old 02-03-2011, 01:57 PM
EAS EAS is offline
EAS is on a distinguished road
out of round mill
I have a Bridgeport mill with a 3axis controller. It also has a kwik switch 200 spindle. The tooling runs out of round by about .006. Does this seem like the kwik switch is in wrong or the spindle bearings are bad. When I grab the spindle It will move, but a little maybe .0005. I have run mills with much worse "play" and they don't seem to be out of round like this. The bearings don't sound bad at all but could this be the problem?
Old 02-03-2011, 06:47 PM
Is the spindle OD or the bore it slides in (or both) possibly worn oversize? We're having that problem on a similar machine right now.
We will bore the head oversize to restore geometry, plate the bore and grind back to size. The spindle/quill OD will be ground undersized, plated oversize and ground back to size.
Spindle bearings will be replaced during the re-assembly.
Dick Z
DZASTR
Old 02-03-2011, 10:18 PM
EAS EAS is offline
Thank you.
This is something I will look into. You probably saved me a lot of time I would have wasted by just replacing the bearings.
Round Part Workholding in Mill dksoba General Metal Working Machines 2 09-20-2010 07:30 PM
Round column mill? bearwen Benchtop Machines 4 01-06-2010 08:02 AM
Round Column vs Dovetail Mill davidshobby General Metal Working Machines 12 05-12-2008 12:00 PM
Round column mill rodzilla Benchtop Machines 4 08-15-2007 08:00 PM
Round column mill SCROMAL General Metalwork Discussion 1 06-18-2006 12:23 PM
