Results 1 to 2 of 2
Thread: Trying to build a CNC machine
    Dec 2008
    Sweden
    Hi all of you.
    I'm new to this forum (reged a long time ago, but was never active) and come here to seek help from all experienced people when I try to build my own CNC machine!
    I have very little knowledge about CNC machines. Electronics has been my former hobby but never building machines, just so you know, Im a rookie here.
    Got a X-Y table from a friend about 2 years ago. Two stepper motors fitted, and it looked like a strong base to build on.
    Tried to read up on the CNC subject on different forums but I felt it was to much at the moment. Project was put aside.
    Now I've picked up this project again and intend to make something out of it. I need a mill..
    I hope to be able to mill aluminium when its done.
    First let me show you what I have to start with.
    This is how I got it. No electronics or anything. And no Z axis... my biggest headache.
    When I got the table the top aluminium plate was full of glue, so I guess that is what its been used for.
    The whole assembly feels very rigid. No play that I can feel anywhere.
    Feels like a good base for this project?
    This is what I know about it.
    The markings on the ballscrews says FHPC 20.
    The screws are 20mm diam and 5mm/turn.
    Rods are 20mm diameter.
    Linear bearings say "W.Germany, STAR, 067-20"
    Steppers. Superior electric, M093-FD11 6-wire
    I have built 3 stepper controllers using Allegros A3979 stepper IC with built-in translator. This was also done 2 years ago.
    The controllers are rated max 2.5A and the two steppers on the table are rated 5.5A.
    A guy on our swedish electronics forum designed the controller.
    Last week I finally finished building the motherboard for the controllers. No optocouplers yet, but there will be when I build a new version of the motherboard.
    I will probably have lots of questions while Im building this, and my first question is, how do I best design the Z axis?
    This is a big problem for me because Im not really sure how to begin working on the machine.
    I need it to be stable enough to mill aluminium.
    I have access to MIG welder, angle grinder, drill press and simple tools like that in our workshop.
    I am trying to build this on a low budget but I am aware I will have to spend some cash to get precision.
    The stepper for Z will be a NEMA 23 which I allready have.
    Please help me get started!
    Dec 2008
    Sweden
    I just tried google sketchup.
    Would this be a good start? Or will it be unstable and ruin my machine?
    Welding this to the bottom of the table frame.
    Imagine the X-Y table sitting on the bottom bars in the Z-frame in the sketchup image.
  1. New Machine Build- My Second CNC machine build!
    By Toaster55 in forum DIY CNC Router Table Machines
    Last Post: 06-22-2011, 07:50 PM
  2. Need A Quote- CNC Machine Build
    By CyborgCNC in forum Employment Opportunity
    Last Post: 08-04-2009, 04:28 PM
  3. Newbie- First machine build
    By Barry Thomas in forum Want To Buy...Need help!
    Last Post: 07-25-2009, 07:38 AM
  4. Need help to build my own CNC machine
    By enixidfrag in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 05-04-2008, 05:22 AM
  5. Use the second machine to build the first!
    By Madclicker in forum CNC Wood Router Project Log
    Last Post: 06-27-2007, 12:29 AM
