Old 01-30-2011, 09:32 PM
klyons is on a distinguished road
Unhappy 0.5x10x100mm slot cut
I have designed a part to be a water flow channel. The part must be created from one piece of 304 stainless steel. It has some various holes and such which are rather easy to machine. However, through the entire length of the piece (100mm) there needs to be a rectangular slot cut. The dimensions of the slot are 0.5x10mm. The inside surface finish would ideally be about 5 microns. I'm a college student and do not have any of the equipment to do this myself. Machine shops I have talked to do not have the capability. I am thinking sinker EDM is an option but I have been told that approach will be difficult. Any other options or advice? Thanks!
Old 01-30-2011, 10:40 PM
Crispymetal-fab is on a distinguished road
I would imagine you could find a shop and wire EDM your part. Our shop has made some parts that we have ladders out, bent, and then sent out to have a 3.6" long by .188" deep by .019" wide slot put in by wire EDM.
Old 01-30-2011, 10:45 PM
Sorry, "ladders" should say "lasered"
cutting a slot with a t-slot cutter cncuser1 Mastercam 11 09-09-2008 09:02 PM
t-slot fatboy55 General Metal Working Machines 9 08-02-2007 05:28 PM
Coated Carbide 4Flute Endmill, 3Flute Slot Drill, or 2Flute Slot Drill? weaston General Metalwork Discussion 7 04-11-2007 09:00 PM
T-Slot dafowfidy Syil Products 2 02-24-2007 02:28 AM
