Old 01-27-2011, 09:24 PM
vpmachine is on a distinguished road
220V/208V?
i just got a small Boxford lathe with a 3phase motor ( unsure of h.p.) that works with 360v/208v 3 phase power (it is currently wired for 208v). My shop has 220v 3 phase power, I guess my question is how big of a fire would I start by running it on 220V 3 phase. Thanks for the help.
Thanks,Vince
Old 01-27-2011, 10:06 PM
Al_The_Man's Avatar
You are probably not going to notice much difference, only if you start running at very high loads, the current may exceed the motor rating, so the load factor is something to watch for.
If you install a VFD you can tailor it to suit the motor rating.
Old 01-28-2011, 12:54 AM
Ed from NY is on a distinguished road
Originally Posted by vpmachine View Post
My shop has 220v 3 phase power...
If you are in the US, and you are running a phase converter, and you do not have a transformer, chances are your power is 240V. Not that it makes much of a difference.
Need Help!- VF5 208V conversion? machinist007 Haas Mills 2 08-04-2010 07:18 PM
240v supply and 208v motor isu19151@verizo Bridgeport and Hardinge Mills 8 11-29-2007 01:23 AM
which 220v mig to get? keebler303 Welding, Brazing, Soldering, Sealing 5 12-14-2006 09:06 AM
208V 3ph machine on 240V 3ph? DennisCNC General Electronics Discussion 2 11-21-2006 06:34 PM
Yet another 120v to 220v Konstantin General Electronics Discussion 4 02-24-2006 01:57 PM
