Old 01-23-2011, 01:07 PM
Jig Maker is on a distinguished road
Grease problems . . .
I cut only aluminum with with my router, and even though I use a vacuum it's not doing what it should and I need to redesign it. In the meantime, the chips are building up on the grease of the worm screws and the x screw especially gets clogged. Coupled with the fact that the machine operates at whatever the outside temp is, the white lithium seems to get too gummy once the temps drop below the low 30s.
My question is what should I use to lube the worm screws, and should I use the same lube on the guide rails for the linear bearings for the x and z axes? I laid the x axis worm screw beside the y axis after I'd cleaned the x, but it was much worse than the y you are seeing pre-cleaning.
Name:	worm screws x-y.jpg
The x worm screw had so much gunk built up at the female part it rides on (sorry cannot find a manual for this machine don't know the nomenclature) that the servo was seeing enough resistance to trip the reset button on the back of the controller.
I'm thinking of trying tranny fluid. Bad idea?
Oil or Grease ranchak General Metal Working Machines 1 03-15-2008 02:59 PM
Cleaning off the grease Involute Syil Products 5 04-16-2007 01:36 PM
#1 grease? Have Blue Tree 11 12-03-2006 08:24 AM
oil or grease? hpghost DIY-CNC Router Table Machines 2 08-30-2005 02:20 PM
grease?? DLMACHINE Machine Problems, Solutions , Wireless DNC, serial port 0 04-22-2004 12:27 AM
