Old 01-21-2011, 05:20 AM
sparow is on a distinguished road
How to make my lathe CNC
Hello everybody,I come from Bulgaria.Recently I bought a lathe its bulgarian model C5 1500mm. between centers.Its semi-professional machine.I rebuild it from scratch.Firstly i wanted to put a step -motors on X and Y axles but I can't make carvings-i need servo motor as main to syncronyse carving screw and spindle's rpm.
Tonight I'm going to attach photos of my machine.
I am open for every suggestions .
Please to excuse for my english.
Old 01-21-2011, 06:47 AM
Fastest1 is on a distinguished road
I would like to see the lathe. You cant make carvings? You did say a lathe. Btw your english is fine, much better than my attempt at any other language than english :-)
Old 01-21-2011, 01:09 PM
This is it.Tomorrow i'll make more photos and if you have any questions about-ask ,i know him az my fingers
About carving i mean Thread.
Old 01-21-2011, 09:50 PM
Ed from NY is on a distinguished road
To make threads you need to synchronize the spindle with the Z feed. That can be done either by replacing the old lathe motor with a new motor which can be controlled electronically or by adding an encoder to the spindle so that it sends a pulse to the electronics in order that the Z can be adjusted.
Old 01-22-2011, 04:48 AM
Yes,thats right. I our small country between 80 -90s. we have very big production and supply of CNC lathes,mills,centers.
In my lathe main motor is 3kW. 1500rpm.In the begining i have been ready to put a fast-move motor/from citroen steering/.
I have a base to look- a old bulgarian cnc lathe.Main motor is servo. I need something like that ,but it's all greek to me about electronics.
Old 01-22-2011, 06:50 AM
Here more photos of the machine. I took it from one old retired man. I was in very bad condition/10years nobody has touched him/and before he was worked on only few months,and lathe was almost new it was all in rust and when he moved the machine fall down and some things-broke
It took me 2months to renew but its worth.
I buy the machine for 500lvs/~250$/ with a lot of instruments/see pic/
Old 01-22-2011, 12:04 PM
May be someone else can help you with the electronics. Did you try going through some of the log projects?
Have you been using the lathe? If not, may be you can make a few parts on it to see if you have any problems in the underlying machine itself. Then if you are happy with the results you can continue with the conversion.
Old 01-22-2011, 06:22 PM
I can't find anything useful for my case.
The machine is veeeery old it have been produced between 1950 -1970
Its very slow to work-example-i have to change some gears to make different therads and etc.I face problem only with the conception -where to find and buy exact motors and other to computerize my machine.
How would you make this part in MCAM Lathe? SRT Mike Mastercam 3 03-31-2010 08:15 AM
how to make threaded rod using lathe machine chepot Linear and Rotary Motion 4 04-05-2009 08:01 AM
What CNC lathe can make these parts? squale Mini Lathe 65 11-15-2007 04:56 PM
Does HF make a lathe... bryanrabb Mini Lathe 11 12-03-2006 05:22 PM
Anyone here make their own CNC lathe? Zumba General Metal Working Machines 6 04-30-2006 09:01 AM
