Old 01-20-2011, 12:06 PM
pikamonk is on a distinguished road
"Flip" DSTV coding
Hello. Hopefully someone knows how to read .nc1 files. The customer has a peddinghaus PCD-1100. The problem is that when they load the beam, they load it into the "back end" of the machine, where in most cases the beam is supposed to go out of. So they load it backwards. Reason for this is that they had installation restraints and didn't have much choice.
So, when they load up our nc1 file, it is shown on the operator's screen as "backwards" & the machine gets confused and I guess attempts to flip the beam around since the faces in which the holes are punched are opposite to what it expects.
I'm hoping that the solution is to swap the o&u, v&h faces and that will work... but that may not even be the problem. I've attached the NCfile sample that they have sent me... hopefully it can explain it better to someone who can read it.
edit: We are using tekla structures to output ncfiles. Strucad file is an example of what was sent to us.
File Type: zip 3026.zip‎ (516 Bytes, 11 views)
Old 01-20-2011, 12:08 PM
Couldn't upload .nc1 files so zipped it. Also will post text here for easier access...
ST
** STRUCAD V15.0
5117
3026
1
1
350W
1
W410X39
I
6514.92
399.00
140.00
8.80
6.40
17.20
39.200
0.000
0.000
0.000
0.000
0.000
BO
o 1587.92u 32.00 21.00
o 1587.92u 108.00 21.00
o 1727.92u 107.86 21.00
o 1727.92u 32.00 21.00
o 3350.92u 32.00 21.00
o 3350.92u 108.00 21.00
o 3490.92u 107.86 21.00
o 3490.92u 32.00 21.00
o 5112.92u 32.00 21.00
o 5112.92u 108.00 21.00
o 5252.92u 107.86 21.00
o 5252.92u 32.00 21.00
BO
v 39.92o 324.11 21.00
v 41.92o 248.14 21.00
v 44.92o 172.17 21.00
v 46.92o 96.20 21.00
v 6467.92o 321.95 21.00
v 6469.92o 245.99 21.00
v 6471.92o 170.01 21.00
v 6473.92o 94.05 21.00
AK
o 6503.61s 0.00 0.00
0.00 0.00 0.00
0.00 140.00 0.00
6503.61 140.00 0.00
6503.61 0.00 0.00
AK
u 6514.92s 0.00 0.00
6514.92 140.00 0.00
11.31 140.00 0.00
11.31 0.00 0.00
6514.92 0.00 0.00
AK
v 6514.92u 0.00 0.00
6503.61 399.00 0.00
0.00 399.00 0.00
11.31 0.00 0.00
6514.92 0.00 0.00
AK
h 6514.92u 0.00 0.00
11.31 0.00 0.00
0.00 399.00 0.00
6503.61 399.00 0.00
6514.92 0.00 0.00
SI
o 500.00s 30.00 0.00 8 5117 3026
EN
AK
11.31 0.00 0.00
0.00 399.00 0.00
6503.61 399.00 0.00
6514.92 0.00 0.00
SI
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
Has anyone looked at the "JET" or "Shop Fox" manual machines? boosted General Metal Working Machines 12 03-04-2007 09:33 PM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 09:09 AM
